Clarification of my plan
Susanne2
I signed up with Public Mobile Sept. 22, 2020 at $25.00 a month plus $3.00 tax for a total of $28.00 on autopay.
- I was told that I have unlimited Canada wide talk time. Is that unlimited incoming and outgoing?
- I was told that I have unlimited text and picture messaging. Is that unlimited incoming and outgoing?
Data: 3 G speed
How much data do I get with autopay?
I am unclear about FaceTime internationally - is it unlimited?
11 REPLIES 11
@Susanne2   Yes international texting is unlimited for sending and receiving, however, all of your plan services only work while in Canada.
@Susanne2  Yes international Text and picture is included @Susanne2
@Susanne2  International texting and messaging are unlimited as well
Susanne2
I forgot to ask about International texting and messaging - is that unlimited for incoming and outgoing on my $25.00 plan?
@Susanne2 @Yes international text and picture is unlimited
@Susanne2  International texting and picture messaging are unlimited too
Susanne2
How about International texting and picture messaging? Is that Unlimited on my plan?
@Susanne2
yes to unlimited incoming and outgoing.
$25 plan is on 3G speed, means you can use it on LTE network but capped at 3mpbs
you can use FaceTime on wifi to call anyone.  if you use FaceTime on Mobile data, you can, but it. will consume your data.  You have 1Gb on this plan
YES incoming and outgoing unlimited calling whilst you are in Canada on the $25 plan.
YES incoming and outgoing unlimited text and MMS (picture messaging) whilst you are in Canada on the $25 plan.
Data: 3 G speed
Yes
1 GB (with or without autopay)
FaceTime is a wifi product, you just need to be connected to wifi areas for it to work, or use your data on you plan.
@Susanne2  see above
dust2dust
1. Yes.
2. Yes.
3. 0. 1gb is the plan amount.
4. It uses the internet so either wifi or your limited cell data.
Adding - Oh 2020. You should have several years of freebie data and international calling add-ons.
@Susanne2 @Yes that’s correct , auto pay is if your on old rewards . But you get 1G of data . If not your on points and that’s a bit different but you still earn rewards
