08-08-2018 07:09 PM - edited 01-04-2022 06:41 PM
is MMS data metered or otherwise counted toward the plan's Data limit?
https://www.publicmobile.ca/en/on/plans/30for500MB-3Gspeed
Thanks
08-09-2018 01:15 AM
That was what i said earlier???
08-09-2018 01:13 AM
@danlee to send annd receive mms you need data to be on. you do not need a data plan as mms do not consume data
08-09-2018 01:06 AM
My plan do not have data and i am able to send MMS, i do need to turn my mobile data on in order for it to send/receive.
So no MMS does not consume any of your data.
08-09-2018 12:47 AM
Yes I can confirm this as I have used almost my whole data allotment, so I have been keeping close tabs on it before my renewal, next week
08-08-2018 11:53 PM
You will need data turned on on your phone to make it work, but as the others are saying, yes, you can send MMS without using your data allotment.
08-08-2018 07:26 PM - edited 08-08-2018 07:29 PM
It's a different protocol and MMS is usually delivered over a different APN specific to MMS messaging only. I've never seen MMS data touching your data package at any mobile carrier, and you usually don't even need a data plan to send and receive MMS.
08-08-2018 07:14 PM
@rybshik, MMS consumes wireless data only. However, it is never metered and will not count against the data allotment. As long as you select a plan with text, you will have unlimited MMS.
08-08-2018 07:12 PM - edited 08-08-2018 07:20 PM
