Plan details
KeroppiKensukei
I'm planning to go to the state's, and wanted to clarify the details of my plan.
It says "
  • Unlimited Canada-US wide minutes and messaging plus unlimited international text and picture messaging++"
Does this mean I can make unlimited calls  to either Canadian or US numbers while I am in the states and not be dinged?
7 REPLIES 7
cammar
You are correct... personally I'd take a look at available plans, i just saw 75gb for $35...exact plan as you have right now just more data... and for only $1 more. Good Luck!
Boki
What plan do you have?
Current PM plans are CAN-US-MEX and Canada-wide.
If you have current Can-Us-Mex plan then your phone will have full service in any of these 3 countries.
KeroppiKensukei
KeroppiKensukei
Awesome. Thank you!
hairbag1
@KeroppiKensukei
you'd never be dinged anyhow as Public Mobile is a pre-paid service.  As such, you pay ahead of time for whatever you need and you won't get a bill later on for overages or anything else. If you use up all your data allotment...it just stops until next renewal (or you buy an expensive add-on) You can call most any US and Cdn number and have unlimited international messaging without worry. Just make sure the cell you're using is on the Public Mobile whitelist of VoLTE enabled cellphones as PM has chosen to not enable all cells at this time.
@KeroppiKensukei
Yes you are correct. The Canada/USA plan includes everything in both countries so no surprised roaming charges.
But you need to enable VoLTE to make calls as 3G is decommissioned in the USA. Also your phone must be on the list of phones on the whitelist to work.
Here are more info.
https://www.publicmobile.ca/en/on/get-help/articles/volte?_gl=1*1qks5fo*_gcl_aw*R0NMLjE3MzA4MTg5ODgu...
slusagm
What plan do you have?? If you have a Canada-US plan, then yes all included
It sounds like you have the proper plan but Can you post the rest of the details just to confirm?
