US/Canada long-distance add-on
alexf
Hi, I purchased a 200 minute US/Canadian long-distance add-on on Aug. 7th from Hawaii. My phone is still saying I don't have long-distance and I still can't make calls. This is despite the money coming out of my account and the add-on showing as having been purchased. My trip is over tomorrow so it's pretty much pointless at this point, but I'm kind of frustrated because now I've spent the money and gotten nothing in return. (I should note that I'd previously purchased the same add-on in July to correspond with the first ten days of my trip.)
Just wondering if anyone has any thoughts. I've turned the phone on and off, and it's not a data plan so "data roaming" shouldn't matter.
Thanks!
alexf
Thanks, at least I understand why it hasn't worked -- a problem with me, not with the phone or company. Won't repeat the same mistake next time!
@alexf
As stated above, you bought the wrong add on.  If you are in Hawaii, you should have bought the US roaming packages (that last 10 days).  Too late now, I guess.  You can still use the 200 minutes for calling the United States from Canada.  There is no expiry date on the add on minutes.
For example,
U.S. Talk, Text and Data Bundle
Unlimited Talk, International Text and 250MB Data for just $20 for 10 days.
U.S. Talk and Text Bundle
Unlimited Talk and International Text for just $15 for 10 days.
U.S. Talk Only
Unlimited Talk for just $8 for 10 days.
Hope that you had a great time in Hawaii....
MoreYummy
Are you traveling outside of canada or in canada?
That addon is only for use while you inside canada.
Also sometimes reboot helps to pick up the new feature
