01-21-2020 07:24 PM - edited 01-05-2022 09:07 AM
Simple fix if you have your Mobile data "off" and your account shows more data used just toggle airaplane mode to on for 30 seconds then back off, your account will reset I do this every 2 days
01-22-2020 03:57 AM
Forgot to mention, if your phone has a data saver setting activate it as well! Most
01-22-2020 03:54 AM
@caseyshea89 wrote:Limit background data usage by turning off in app settings and in phone optimization
This has been discovered to be an anomoly in the Public Mobile counter.
01-22-2020 03:45 AM
01-21-2020 08:23 PM
@Luddite wrote:
@darlicious wrote:@Clive2 There is still some mystery very minor data leakage out there that has yet to be explained and does not reset. It's a few kb but still an enigma.....
Perhaps PM uses the enigma machine to calculate data usage as secret messages.
@Luddite Publics portable puzzle propagating perpetrator?
01-21-2020 08:16 PM
LOL nice one
01-21-2020 08:03 PM
01-21-2020 08:01 PM
@Clive2 wrote:But ya that phone you hooked me up is working great
I'm happy to hear you're satisfied with your purchase. It's great value for a phone of that calibre. It also appears most of the camera software issues have been corrected in later manufactured versions of that model of the Umidigi A5 pro. It's still not the best in low light but you can't complain at $130.
01-21-2020 07:46 PM
k
01-21-2020 07:45 PM
@Clive2 just so you know you can edit your posts to include all of the above posts in one post. There isn't a need to make a post for each sentence. As well if you are replying to a specific post by someone it helps to hit the quote button when you do your reply. This will let everyone know who you are replying to.
01-21-2020 07:41 PM
01-21-2020 07:35 PM
My base is 3mb then jumps to 8mb, after reset goes back to 3mb
01-21-2020 07:30 PM
better than nothing lol
01-21-2020 07:30 PM
Mine does not set back to zero, but sets back to what had to used to set up my account, so it does set back
01-21-2020 07:27 PM
