03-24-2025
02:31 PM
03-24-2025
04:36 PM
computergeek541
Why does my data usage shows up at odd hours when I’m on WiFi??
03-24-2025 02:35 PM
hi @CrazyElect
the usage you saw was about 12+ hours late. PM just post a lump sum of the usage for the date.
if you want the most update usage, check the usage on the overview page
03-24-2025 02:34 PM
PM does not update the data usage constantly. In fact, it only update it twice a day.
So, any entry you see is just a total usage between that timestamp and the timestamp of the previous entry. The early morning usage you see on the Usage log does not mean it was used in the morning but a total usage for the last 12 hours.
Also, for correct usage reading, always use Incognito mode to login My Account to avoid reading cached old info
03-24-2025 02:32 PM - edited 03-24-2025 02:33 PM
@CrazyElect wrote:Why does my data usage shows up at odd hours when I’m on WiFi??
Hi @CrazyElect
Public Mobile updates their data usage every 12 hours. So it may look like you're using data while on WiFi, but you're not. The stats are just a little outdated.
We are NOT Customer Service Agents. We do NOT work for Public Mobile. We are Customers just like you who try to help others while earning credits towards their cell phone bill. Please do not share any personal information with anyone here or in a private message.
