07-12-2021 07:04 PM - edited 01-06-2022 03:00 AM
Hello,
I enabled an option a while back that would block my phone id when I called someone. I can't figure out how to reverse this, so when I call others, they can't see my name and don't answer. Please assist me with this one. Thanks 🙂
11 hours ago
07-14-2021 02:46 AM
There are ways to do it in the phones menus, but here is the definitive way to set/clear outgoing network default CID blocking using standard GSM codes with Public Mobile on any phone:
07-12-2021 07:17 PM
@danielvic you did something like this before?
To block your number on iPhone:
1. Go to Settings, tap Phone
2. Press Show My Caller ID
3. Use the toggle switch to show or hide your number
To block your number on Android:
1. Open the Phone app, and open the Menu
2. Select Settings, then Call settings
3. Click on Additional settings, then Caller ID
4. Choose “Hide number” and your number will be hidden
To reverse this feature on Android, choose “Show number” or “Network default”
You can also use *82 to unblock your number in case your call gets rejected temporarily. Some providers and users will automatically block private numbers, so using this code will help you bypass this filter.
07-12-2021 07:12 PM - edited 07-12-2021 07:23 PM
07-12-2021 07:09 PM
@danielvic : Dig down in all the settings of your dialer app. On my Android it's called Show your caller ID.
