02-05-2025
04:11 PM
02-05-2025
06:28 PM
computergeek541
My phone will recieve Texts and Send Texts, However no incoming or outgoing calls.
Also My honor 8x shows no call forwarding,call waiting or caller ID .
Network or Sim Card error shows up we have 2 honor 8X phones and the one thatnis havivg trouble has a phone number from another province?
Thanks Grant
02-13-2025 05:08 PM
Good to know. I always though it needs 2 bands for a stable connection encase one drops-off.
02-13-2025 03:46 PM
Thanks my Honor 8X Started to receive and send calls on its own. May of been a network issue,
Thanks For your support
02-05-2025 06:30 PM - edited 02-05-2025 06:32 PM
@BKNS27 wrote:I don’t think your Huawei Honor 8X is compatible with PM frequencies.
https://www.publicmobile.ca/en/on/get-help/articles/check-your-phones-compatibility
It shows the it has B5 (850) and B7 (2600) on 4G and 3G.
You need at less 2 frequencies in 3G and 4G to work. The Honor 8X only have 1 in each band.
There is no rule that says that you need at least 2 of the 3G and 4G bands for a phone to work at Public Mobile. You only need 1 compatible band and that band has to be available at that location.
02-05-2025 04:54 PM
