Unable to register credit card
tlocean
Morning guys,
I have a problem on Register credit card for AutoPayment, no matter which card i register(RBC or CapitalOne)
It shows me:
I called those banks already, they are OK .
Can anyone help me ?
SLDec
Thanks for the suggestion - have contacted the Mod team!
@SLDec wrote:
I have also had this issue. There is no problem with the card. I have tried to use my husband's card and had the same problem. I entered my address details correctly and I am still unable to make a payment or register my credit card for autopay.
How should I proceed?
You can go to a 7-11 type of retailer and get a payment voucher, then call 611 to add it to your account. You can deal with the credit card issue later.
@Anonymous wrote:
 @tlocean
If you have a unit # then don't use the apt# field.
Type in the address exactly as it looks on your billing address.
Don't use a space in the postal code or drop the last #.
Has this solution not worked for You?  Too many attempts can lock you out of the system. If it hasn't it is advisable to clear your browser/cache, use secret/incognito mode when making account changes. Be sure the address is what your c/c has on file.
Otherwise you must contact a moderator for assistance via Simon (?)
SLDec
tlocean
@Anonymous
Thank you so much !
I do have a Unit No.
It works now.
 @tlocean
The problem now might be that you've been locked out due to suspicion of fraudulent activity. In which case you'd need moderator assistance.
