How to contact customer support
Iainrs
How do you contact customer support to register a new SIM when unable to load app
2 REPLIES 2
CS_Agent
Customer Support Agent
I sent you a private message. You can view and reply to it by accessing this link:
Socrates8567
Hello.
You can log in, it's the chat bot bottom right corner or use the following link.
If you can't log in, here's the direct link
They will reply here.
