02-27-2024
04:33 PM
02-27-2024
07:37 PM
computergeek541
I activated the $34 50gb plan today but not able to receive confirmation password or otp. Even if I keep pressing resend, it doesn’t take me to email option.
02-27-2024 05:14 PM
I can’t request porting because I am unable to go to that screen.
02-27-2024 05:13 PM
Yes, I tried. I did get the code. After entering it, it took back me to the same screen again and loop continued.
02-27-2024 05:13 PM
I tried but it took me on a loop and came back to same screen prompting me to enter the password.
02-27-2024 04:55 PM
When I just signed up I had to do resend code and then to email.
02-27-2024 04:36 PM
Did you try using computer to resend confirmation code to email?
02-27-2024 04:34 PM
did you request porting? is the porting completed? If not, better wait for the port to complete and this issue will be a non-issue
