Unable to receive calls
John56738
I’ve had a SIM card with public mobile for a few month but have just stared to use it. I’m able to make called with the SIM card, but all incoming calls automatically go to voice mail. How can I fix this?
@John56738
Does your old SIM still work?
If it does then porting wasn’t completed because you need to reply to the text confirming you are porting over to PM within the 90 minute window.
@John56738 wrote:
Yes, but it was my old number, and the forwarding was done a few months ago.
HI  @John56738 was the forwarding still on??
and was the phone used with another sim card before?  Try to Reset All networks first
John56738
John56738
It isn’t, a different sim card works perfectly.
hairbag1
@John56738
check in settings to make sure you haven't enabled Do Not Disturb.
@John56738- did you port in (transfer) your number from another carrier?
