05-31-2023 04:19 PM
Hi, I need to access my receipts for all of 2022. Unfortunately, i can't download ones that are older than 180 days. PLEASE HELP!! thanks
05-31-2023 08:03 PM
@JL613 You can go back 12 months yourself. Go to payments, payment history link and change the filter. You can select back to Jun 2022 to get receipts for Jun - Dec 2022. For Jan -May 2022 you'll need to contact CS Agent and ask them if they can provide those to you.
You can contact them here,
05-31-2023 04:22 PM - edited 05-31-2023 04:22 PM
hi @JL613 yes, download is here but not too old the receipt
please submit ticket with agent at: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
05-31-2023 04:21 PM
@JL613 Did you select 12 months filter option? It's available as I tested it a little while ago. Use incognito/private mode on browser first too.
05-31-2023 04:20 PM
