2 hours ago
I have switched phones recently and am unable to send and receive pictures in the form of texts. Messenger works fine. The problem is with texts. I have checked apn settings and no luck. I have also tried removing my sim and reinstalling it.
2 hours ago
Hi. I have a UMIDIGI G9C
I have re- added the apn as above and restarted phone. Still no luck.
I do have the mobile data switched on.
2 hours ago - last edited 2 hours ago
hi @Dano2100
what phone do you have?
but first, make sure you have mobile data turned on, Picture text (MMS) needs mobile data enabled
and you can also try Reset Network settings
if you have iPhone, make sure you update Carrier Profile
if you have Android, check the APN, should be like this
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
APN Type: default,supl,mms
