Unable To Activate Account/Locked out
jstn123
Password consistently shows as incorrect when logging in. Resetting password does not resolve the issue.
7 REPLIES 7
Yes you've tried that or yes it worked?
jstn123
Yes
jstn123
This does not work. Tried various browsers, incognito mode etc.
Chalupa_Batman
Oh. One more idea, have you tried downloading the app and trying that?
HI @jstn123
You are trying to activate new account?  are you using app?  If you are not, please start again using app.  Or if you have been using app, uninstall and reinstall before trying again
@jstn123  And your trying on the app to complete the activation ? If no luck please submit ticket with support using this direct link
send a  private message   To CS_Agents click
Chalupa_Batman
Try going to your browser settings and clear your cache. Then restart your browser and try again.
