Unable to go to My Account
LindaPriestley
Every time I log in goes to resume activation. Been trying since yesterday. Unable to log into account or community.
@LindaPriestley  Should try in the app and if you have been try to uninstall it then reinstall it see if that helps at all . If still no luck please use this direct link to customer support
send a  private message   To CS_Agents click
HALIMACS
@LindaPriestley
recommend using a completely different browser on a different device, if available
Otherwise, you might want to clear system cache and cookies, and use an incognito /private tab to access it.
statusquo
You need to use a fresh browser or clear your cookies because of caching problems with public's website.
But you are logged into the community right now?
