04-22-2025 01:34 PM
Hey everyone
Wanted to post her to confirm before purchase. I'm thinking about buying a umidigi g100A as a bridge phone before I decide on something more pricey.
Can anyone confirm if it's usable on Public Mobile network? I know the 5G seems to be not available but wanted to make sure it will actually be ok for making calls and using data.
Thanks
04-22-2025 04:01 PM
It should work for now if your area of calling has both 3G bands 850 Mhz and 1900 Mhz. However, PM is slowly refarming the 3G 850 Mhz band to LTE and that has caused some customers in those affected areas to have talk issues with phone without VoLTE PM compatibility.
Here is additional information:
There have been issues with talk with the Public mobile network recently. Public mobile has been changing the 3G network (switching 3G 850 MHz band to LTE). Here is some additional information:
https://www.publicmobile.ca/en/get-help/articles/850-turndown
If your phone is not VoLTE compatible with the PM network and the 850 MHz 3G band is not available in your area, your talk services will be affected.
04-22-2025 02:45 PM
From the UMIDIGI site
Network Bands:
2G:B2/3/5/8
3G:B1/2/4/5/8
4G:B1/2/3/4/5/7/8/17/18/19/20/26/28AB/66/38/40/41
04-22-2025 02:30 PM
I appreciate all the help. As I mentioned in my original note, was looking for a cheap "bridge phone" until I can get some freedom and purchase something more useful - probably the Pixel 9a. I'm currently have a A52 and it's been terrible lately
04-22-2025 02:07 PM
hi @MarkSquires
your phone has both the 3G bands and some of the 4G bands needed on Public Mobile network and it should work
But it is not a phone on PM's VoLTE whitelist, so voice calls might not work well if it does not connect well on the 3G network
04-22-2025 02:06 PM
Hi @MarkSquires,
The Umidigi G100A should work on Public Mobile for calls, texts, and 4G data, as long as it supports the right network bands. Here’s what you need to check:
Public Mobile (Telus Network) Key Bands:
What to Do:
Note: Some Umidigi phones don’t support VoLTE on Canadian carriers, which may cause call issues in the future as 3G networks shut down. For now, you should be fine for temporary use, but don’t expect 5G or top-tier performance.
04-22-2025 01:50 PM
Best way to confirm if any phone would work with PM service is to FIND such phone and stick SIM into it.
All other advises, 'it might work', 'it should work', etc. is still a risk that it might not work to your satisfaction.
04-22-2025 01:48 PM
Thanks- that's the plan. Kinda cheap right now and on Amazon
04-22-2025 01:47 PM
@MarkSquires wrote:Hey everyone
Thanks
Well @MarkSquires to be honest, you take a risk using a phone that's not on the VoLTE approved list. If it works, that's great! If it doesn't work, I guess it's all about trial and error.
To confirm if your phone will work with Public Mobile, please see this link. These are currently and mildly out of date lists of what can work.
04-22-2025 01:40 PM
@MarkSquires , I have a much older Umidigi A13 pro and it works fine on this service. I would suggest buying from Amazon which has generous return policy if things don't work out.
