02-09-2023 09:45 PM
If we need more time in the USA than 15 days can we just pay another !5 .00 ?
Add-Ons
02-09-2023 09:51 PM
@slingvan if you want to buy the EXACT same addon, you will need to wait 24 hours after the first 15 days addon expired.
If it expired but you do not want to wait, or the first 15 days not expired buy you already need a new one (data ran out), you will need Support help to rebuy the same one, unless you buy a different addon
But even you buy a different addon, you have to remember no 2 addon with TALK can overlap
02-09-2023 09:49 PM
Hi @slingvan
if you buy it the first add-ons US, and you need other one to buy it you need to wait for the first one is end and after 24hr to buying other one, or contact to CSA, they can added right away if needed ASAP.
02-09-2023 09:49 PM
@slingvan There needs to be 24 hour delay between the first one ending and buying same roaming add on again , if you try to do it right after the first one ends it won’t let . You would need to buy a different roaming option or contact support … but honest if your going for more then 15 days I think it’s best to just get local SIM card in your destination probably cheaper and definitely more reliable
