Phone useage
Nikis7766
I just noticed that my phone useage shows numbers I have never called any ideas how that may have happened?
2 REPLIES 2
Neil11
You will need to contact customer service agent to fix your issue. Either via the following link:
If you are having a difficult time, then you can private message CSA:
Send a private message to CSA through the following link :
hi @Nikis7766
if the number ends with 4001, then no worries, they are just voicemail number.  PM usage will shows all he calls going in voicemail as well as when you check voicemail.
