Sim card
10-08-2024 05:09 PM
Hi
My sim card is getting disconnected every couple of days
Do I need a new sim card
Thanks
Service
10-08-2024 05:19 PM
Yes public mobile sells SIM cards but you be best to to get from Amazon $4.99 or pick up from Telus / Koodo store . From PM it can take up to 3 weeks to arrive
10-08-2024 05:18 PM
hi @AmirSourour
faster to buy a new one in person from Telus or Koodo store or buy from Amazon.ca
you can ask PM support for possible reimbursement
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
10-08-2024 05:17 PM
@AmirSourour Then try a new SIM card and sim swap the number in your account profile page like this
SIM SWAPPING profile tabs
This can also be done on the app aswell , if you have any issues ask support to sim swap it for you
send direct private message to support .
10-08-2024 05:16 PM
Its the sim card.
After cleaning, it works for couple of weeks.
Does public mobile send a sim card
10-08-2024 05:15 PM
I did.
Same problem. I even bought a new phone
10-08-2024 05:11 PM
@AmirSourour Can you test your SIM card in another phone to test it and see if same thing happens . Maybe try somone else SIM card in your phone see what happens . SIM cards are usually free from issues you could also try lightly cleaning the contacts on the SIM card . But can’t hurt to try and change to new SIM card only $4.99 on Amazon
