01-29-2023 05:00 PM
I put US add on on my phone yesterday. I paid and saw the payment was received but I may have done it before the prior add on was finished. I was
charged $30 and was $20. How do I get it to work???
Add-Ons
01-29-2023 08:05 PM
Yes, I had 15 day add on plan that expired yesterday
01-29-2023 05:42 PM
Dang this is a stupid system. The problem is that you didn't wait until the first one expired. You can buy a different add-on immediately after it expires but not the same one. You need to wait upwards to 24 hours (maybe 12) to re-buy the same one.
You will need support to fix this.
01-29-2023 05:12 PM
@tbt Try login to My Account using Incognito mode or Private mode on Safari , check the Payment page and see what transactions there, it should how PM took the money and how the money were used
And do you see any amount sitting as Available Fund?
you said you " have done it before the prior add on was finished.", you meant you got another US add-on before, and bought the exact same one before the 15 days expiry? can you elaborate?
01-29-2023 05:12 PM
Hi @tbt
go to your account and is showing Add-ons there,if yes, then go to your setting network and manually put it to T-Mobile, and rebooting device.
01-29-2023 05:08 PM
@tbt - are you in Canada or USA?
Canada you need the 1000 minute USA calling addon.
If in USA you need a Roaming Addon.
$20 is this one below, so hopefully you are in the USA: US Roaming - 1 GB Data (15-day)
But you were charged $30, which is this one: US Roam-Talk Txt 3 GB Data(15d)
Get Help Article for Roaming and things for reference:
NOTE: is this your first addon your purchase or are you buying back to back of same ones?
01-29-2023 05:04 PM
@tbt wrote:I put US add on on my phone yesterday. I paid and saw the payment was received but I may have done it before the prior add on was finished. I was
Turn on data and data roaming. Try manually connect to T-Mobile.
01-29-2023 05:03 PM
@tbt Should be working try and reboot phone and see what add on you have and what’s left
Check add-ons /mins /Data
