New user - no connection
Athenato31
Hello, I am a new user and ported my line over to Public mobile from Telus about 4 hours ago. I have restarted the phone, reset network settings, removed and reinserted the SIM card. However, the phone still has no connection. Is there any way a ticket can be created for support to assist?
Athenato31
Resolved - I ended up setting up a eSIM as my old provider didn’t have a eSIM available.
Athenato31
Sansan
Hi, you can use the chatbot link https://widget.telus.tiia.ai/publicmobile/publicmobile.html
If that doesn't t work then use the next below to send a direct message.
hairbag1
@Athenato31
were you attempting to port your old number to your new Public Mobile account ?
clipped from Help Files...
https://www.publicmobile.ca/en/get-help/articles/transfer-your-number
@Athenato31 if your PM sim card cannot even connects, it is a sim provisioning issue. Easy fix for PM but you will need to engage them by direct message. Private message CS Agent at:
