Number transfer issue.
Sagarghimire
I recently transferred from fizz to public mobile, everything gone smoothly but I got this message
Hey, it's Public Mobile. We're having trouble transferring your number. Looks like you entered an incorrect ESN/MEID. Someone from our team will contact you shortly using your original phone number or the alternate number provided. You can also get in touch via our virtual assistant at: https://urlshortner.tiia.ai/xYpc_I
and now my Boths fizz and public mobile are working which I do not understand why are these working on same number or what.
The link didn't work? Ok message them directly here then.
Sagarghimire
No I was not able to do so.
Sansan
@Sagarghimire , unfortunately no one from Public Mobile will contact you as it indicated.
Did you reach out to them at that link?
They will fix it for you.
