01-29-2023
06:05 PM
01-30-2023
12:21 AM
Dunkman
I'm having problems and need help how do I get a ticket as I can't get it to work
Community
01-29-2023 07:58 PM
@Madashell give us good news 🙂
01-29-2023 07:55 PM
Working with them now
01-29-2023 07:50 PM
Do you mean CS_Agent?
If you want to contact them, just create a ticket on SIMon Chatbot on the bottom of the page or private message on the envelope icon above.
01-29-2023 07:34 PM
Thanks everyone.. Looks like I have to start from the beginning with cs It is what it is
01-29-2023 06:49 PM
Further to your other thread earlier that people aren't following along with:
https://productioncommunity.publicmobile.ca/t5/Get-Support/My-add-ons/m-p/940934#M648553
follow the above methods. When you get through to the ticketing forms, you'll log in with your community login and then it gives you the option of your account login or your pin. I've had better luck with the pin option. If you don't remember it then if you can log in to your account then you can change it there.
01-29-2023 06:20 PM
Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
01-29-2023 06:08 PM
@Madashell if you don't mind, you can try to share your problem and maybe we can help or share workarounds quicker
but if you want to go head open ticket, here are the ways
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
