08-02-2022 02:19 PM
08-02-2022 03:54 PM - edited 08-02-2022 03:55 PM
@Dreameral000 - make sure your public mobile plan is Active in order for any addons to work.
And note, Roaming addons last 10 days, and start as soon as you successfully add them to your account.
US Roaming Get Help article, if interested in reviewing: U.S. Roaming (publicmobile.ca)
edit, spelling
08-02-2022 02:22 PM
Thanks for the quick responses
08-02-2022 02:21 PM
@Dreameral000 of course you can.
Login to My Account and buy it there
Or you can use *611
Once bought, make sure you reboot the phone
Try to connect to T-Mobile or AT&T
If you are buying data, remember to enable Roaming Mobile Data on your device
08-02-2022 02:20 PM
Yes, you can. Login to your account and make a purchase of appropriate US add-on.
