08-02-2022 02:49 PM
I always log in to my self serve on my laptop. Went to try and log in today and it told me my password was wrong. I changed the password. It's still telling me my password is wrong.
Makes it difficult to buy products and manage account when they won't let you in to manage your account.
Any suggestions?
08-02-2022 03:13 PM
@fmckibbon hi if you still can't get in after following the good advice from @softech ask a cs agent to reset your email for you
you will need to open a ticket, to speak to a customer service agent Click here or if you are having issues with Simon you can send private message to a CS Agent here: https://bit.ly/2GGCJzH
08-02-2022 02:57 PM
Are you saving your password on the internet browser?
This is a good idea - it saves you from typing in the password incorrectly or with caps lock on and not noticing etc..
08-02-2022 02:54 PM
I switched to my phone and that didn't work. I'll try incognito next.
08-02-2022 02:52 PM
@fmckibbon do not change the password again for now
Wait 10 minutes, then use Incognito mode or use a completely different browser (Edge/Firefox/Chrome) and try login with the last password you changed to and see if it works
