Two charges
PrairieLeslie
I have two charges showing on my credit card for the month of October. One is the typical charge the second is listed as Self-Serve and is much earlier in the month. My payment history at PM doesn't indicate an additional charge for October.
hi @PrairieLeslie are the 2 charges on Oct 1 and Oct 31st ?
if they are not, if the w charges are within less than 30 days , ask support to check
PrairieLeslie
the earlier charge has the same amount
@PrairieLeslie  If both charges are posted and then offence isn’t sitting in your accounts available funds
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send  direct  private message to support .
send  a  private message   To CS_Agent
HI @PrairieLeslie
so, the charge earlier than the typical one has a different amount?
I think you need PM support to confirm.  please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
