01-20-2025 08:20 PM
Are calls on this plan only while in that country. For example if in the us I can only call us numbers?
while in Canada can I call us and mexico numbers?
tganks
01-20-2025 09:08 PM
I can confirm that with this plan, I'm able to call most any Cdn, US and Mx number as I'm in Mexico now. In order to call Canada or US from Mx, you need to dial +1...then area code...then the number. Additionally, I can receive calls, just as if I were at home...clear as you please. Same with messaging and data...just make sure to enable Roaming Data in cellphone settings. If you frequent US and Mexico....this plan is a must-have.
01-20-2025 09:08 PM
01-20-2025 08:29 PM
hi @ihillman
you can call all 3 countries when you are in Canada, US or Mexico, and of course, you can receive calls in US and Mexico as well
01-20-2025 08:24 PM
@ihillman wrote:Are calls on this plan only while in that country. For example if in the us I can only call us numbers?
tganks
Hey @ihillman
I had the Canada US plan myself. While I was in Canada I'd call my buddies in the US. While in the US I was able to call them as well plus I could call back to Canada. I could text and use my data as if I were back in Canada. It would be the same for Mexico too. Enjoy!
01-20-2025 08:24 PM - edited 01-20-2025 08:26 PM
@ihillman with this plan you can call and receive calls, texts and data from any of them. It will work just as it would if you were still in Canada.
Ensure you have a VoLTE enabled phone on PM whitelist or calls may not work.
01-20-2025 08:23 PM
@ihillman , as long as you are in one of the three countries, Canada, US or Mexico, you can call to any of three countries.
