12-01-2021 11:59 AM - edited 01-04-2022 05:05 AM
I am in the US on vacation. My unlimited 10 day US roaming unlimited talk plan for $8 just expired. I went to purchase another one like I had, but it does not appear to be available. Why….I need to renew this same plan now!
12-01-2021 01:16 PM - edited 12-01-2021 01:17 PM
12-01-2021 01:11 PM - edited 12-01-2021 01:12 PM
Agree the 24 hours way is less than ideal. We are here to just advise OP , original poster, what is happening. I am pretty sure PM is aware of the system limitation and many has voiced their concern. Change here is slow. For now, we are here to suggest what to do with the current system.
Voip is VERY helpful. Save money. Wifi is everywhere. Don't get it wrong, it is not a replacement for actual cell service, but it could be a lifesaver in a family emergency situation. You got it all setup ahead, and find a wifi and you need to make the call. Better have something than nothing.
12-01-2021 01:11 PM
I agree. PM please fix this ASAP
12-01-2021 01:02 PM - edited 12-01-2021 01:03 PM
That 24 hour wait....needs to be fixed!!
If you know date of time of purchase you should be able to buy another 240 hours and 5 minutes later.
OR
Be able to buy 2 at once and let them run successively
OR
Be able to buy another and let the second one run successively
Voip or App is not helpful if you are travelling and no wifi available. What if you need constant communication for work or a family emergency? I guess if you are travelling with a spouse or friend you could each buy the plan but one day after each other. But what if you are on your own.
12-01-2021 12:24 PM
you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to
them can solve your issue, they are nice Service Team they will help you 100%.
only them can Add for you or you can waiting after 25 Hr to re-Add,
Here’s How To Contact Customer Support Agent by CS_Agent,and Submit a Ticket,
Good Luck...
12-01-2021 12:09 PM - edited 12-01-2021 12:10 PM
Here’s when and how to contact our Customer Support Agents:
12-01-2021 12:07 PM - edited 12-01-2021 12:08 PM
@Norby you need to wait out 24 hours before you can re-buy.
Or a quicker way, hopefully PM replies quick enough, is to open a ticket with PM support to ask them to buy for you. Load the money first, and open ticket
To open ticket with PM:
1. For faster response (2-48 hours), Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
Start with typing "Submit a ticket", click "Contact Us", click "Other" from the choices, click "Click here to submit a ticket". Then follow to complete the ticket submission.
2. Or you can Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
**Monitor your Community inbox, envelope on the top right, after ticket is opened. CS Agent will reply and work with you via messaging there
For now, use Voip app TextNow to call US and Canada for free
