02-23-2024 01:21 PM
Just used 25 points to buy US roaming for 15days and nothing ,then I purchased US roaming from add ons $17.25 and still nothing please refund me as soon as possible.
02-23-2024 01:25 PM
@jack57 you redeemed the Data/Talk/text bundle and you don't need to rebuy the Talk/Text bundle agian
and data and text are usually very easy to get it working, talk could be slightly more work, depends on the phone
Critical part to US roaming depends on T-Mobile/AT&T coverage and whether you can connect successfully onto either network.
If the phone is not connecting to T-Mobile/AT&T, change the Network Connection from Automatic to Manual and select and test both T-Mobile and AT&T and see which one you can connect.
If your issue is with data, make sure your Roaming Mobile data is enabled and you have disabled your mobile data limiter. Also change your network mode to 4G (and don't try 5G until you can connect and works on 4G)
If your issue is with voice, make sure VoLTE is enabled on the device setting. And if it does not work, try to change the Network to T-Mobile ONLY, and change Preferred Network Type or Network Mode to 2G and see if the calls go through.
Also, you can download VoIP app TextNow as a workaround to make calls and text if you have Wifi or if your roaming has data component and data is working
02-23-2024 01:23 PM
HI @jack57
US roaming needs AT&T or T-Mobile , is your phone connecting to either network? try both network
Also, you shouldn't have 2 add-on, you probably wasted, I would check with cs agent and have them to reverse one of the two (having two could actually worsen the situation)
please submit a ticket with CS Agent here:
02-23-2024 01:23 PM
make sure Roaming Data is enabled in cellphone Settings. Select AT&T or T-Mobile for talk.
