12-24-2018 03:14 PM - edited 01-05-2022 02:53 AM
I used up my 10 day add on in 3 days, and I want to buy another add on. The one I used up still shown as my current one so I can’t purchase the same add on now. Any idea what shall I do? Thanks!
12-24-2018 10:29 PM
@Luddite wrote:
@Jessica_T wrote:With moderator intervention is it possible? Or has it been designed this way to force us to spend more on a higher priced $/MB package?
Yes, the moderators can reset your add-ons. First, make a payment equal to the cost of the add-on (it will show in Available Funds). Then click this: message to moderators to send a private message to the moderator team with your request. Worst case, allow 3 days for them to respond.
Doubt it was "designed" this way. More likely a limitation of the software PM chose, and elected not to rewrite.
@LudditeThanks
@GraceVSo yes, you can purchase another 1GB add-on if you contact the moderator team but will take time for the to respond and confirm your identity.
12-24-2018 10:10 PM
12-24-2018 09:49 PM
@Luddite wrote:
@GraceV wrote:Thank you! Yes , there are other ones I can buy… but is there no way i can buy another 1G add on?
Not until 11 days after first purchase. The system will not allow dupliucate purchases of US Roaming add-ons.
@LudditeWith moderator intervention is it possible? Or has it been designed this way to force us to spend more on a higher priced $/MB package?
12-24-2018 09:34 PM
12-24-2018 08:26 PM
If you want, you can get another US 1GB data Add-on. Just repeat the same process as the first purchase and you're good to go.
12-24-2018 03:27 PM
12-24-2018 03:24 PM
You're talking about the data running out, right? If yes, then you can purchase the other US Data-Roaming add-ons separately, as they will work while the combo. There are a few different add-ons with data available, so pick one you'haven't used yet.
