US calls and txt are not getting received
Andrew007
I bought the US roaming package, and now that I’m in the US, no one in the US can call ( goes straight to voicemail) and no text msg either.
Any suggestions?
8 REPLIES 8
For curiosity, see if volte is enabled. Or evidence that the phone stay on LTE when on a call.
Andrew007
Thanks everyone! It looks like a network reset was the ticket.
@Andrew007 - try restarting your phone, or perform a reset of the device's network settings.
@hairbag1 wrote:
@Andrew007
I had another thought...even without the US Roaming add-on, you should still be able to receive texts, just not able to send texts.
Make sure Roaming Data is enabled in the settings on the phone.
Roaming data doesn't need to be enabled for SMS and phone calls. For those parts of the service, that setting won't make a difference.
hairbag1
@Andrew007
hairbag1
@Andrew007
what state you in ? No PM roaming available in Alaska.
Hi @Andrew007 make sure you able to connect to T-Mobile first.  If it does  not connect, try to manually connect to T-Mobile .  And try in different area
@Andrew007
yes, US voice is hard to connect, try 2 things
first try VoLTE
enabled VoLTE on your device
iPhone: Settings->Cellular->Cellular Data Options->Voice & Data, enable 4G or LTE there
Pixel Settings->Network and Internet->Internet, click on the settings icon besides SIM 1, turn on 4G calling there
Samsung/ Other Android: Settings->Connection->Mobile Data, enable VoLTE there
if that does not work, try to change the Preferred network type or network mode to 2G
see if it works
