02-08-2025 03:57 PM
when I go to purchase a 15 day on for texting in US, will there be an option to use the points I have earned?
02-16-2025 02:58 PM
unnecessary repetition
02-16-2025 02:58 PM
02-16-2025 02:57 PM
02-16-2025 02:56 PM
02-16-2025 02:54 PM
Thank you!
02-08-2025 04:44 PM
To clarify you can't purchase add-ons partially in points. You need to either purchase add-ons with money/account funds OR directly with points, and they are in separate areas of your account.
15 day US talk and text add-on costs 10 points. Personally I always go for the $15 bill credit for 15 points.
02-08-2025 04:42 PM
As long as you have 10 points in your account. It will be a talk and text bundle. Nothing for just texting.
02-08-2025 04:24 PM
@Bones2 wrote:when I go to purchase a 15 day on for texting in US, will there be an option to use the points I have earned?
Hey @Bones2
Plus it all depends what plan you currently have. If it's only a few extra bucks to upgrade to a Canada US Mexico plan, that might have better value in the long run. Something to consider.
02-08-2025 03:58 PM
yes, you can redeem points for US add-on and it is actually cheaper
login My account, then click Rewards on top right to login My Rewards and then go to Catalogue to pick the US roaming add-on you want and redeem
it will add to your My Account and ready to be used within couple hours, so, you can do that right before your trip
