2 weeks ago
My hubby and I each have an account and for the past month or so the calls are constantly breaking and we can't talk to anyone. What is going on? A day here and there we won't have that problem but very few.
2 weeks ago
Thank you
2 weeks ago
remove your screenshot as it has your IMEI, don't disclose in open forum here
go to this page, click X on top right of the image and delete it
https://productioncommunity.publicmobile.ca/t5/media/gallerypage/user-id/561055/tab/all
(delete both images)
your A16 is NOT a Canadian model and hence could be the reason why it is showing not compatible. But generally, a Samsung A16 should be VoLTE compatible and you should have better voice quality.
And when making calls, does the phone showing it connects to 4G or LTE or 5G?
2 weeks ago
no worries, Samsung A16 are good. We have support agent confirmed that some newer models are not added to the database in time, but they are whitelisted on the system and are using VoLTE
so, what left of you is to submit a ticket with PM agent and explain them the current sound issue, they might refresh your account and will have the issue resolved
submit a ticket with CS Agent using Chatbot here:
Type the question "Ticket", Then click the following in order: "Account Management" , "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
2 weeks ago
I check with my IMEI and that's what I got. Doesn't make sense.
2 weeks ago
I have a Samsung A16 and yes I'm using VolTE
2 weeks ago
you haven't tell us what phone you have
2 weeks ago
It didn't work I'm still breaking
2 weeks ago
Ok got it
2 weeks ago
what phone do you have? you know if you are using VoLTE for calls?
Use the IMEI checker to confirm if your phone is on PM's VoLTE whitelist and using it to make calls
https://www.publicmobile.ca/get-help/articles/volte
if you have an older phone that is not VoLTE whitelisted, you will need a newer phone
2 weeks ago
For iPhone
Open Settings, Tap General, Scroll down and tap Transfer or Reset iPhone, Tap Reset at the bottom, Tap Reset Network Settings.
Samsung Galaxy
Open Settings, Tap General management, Tap Reset, Tap Reset network settings
Google Pixel / Motorola / Other Stock Android
Open Settings, Tap System, Tap Reset options, Tap Reset Wi-Fi, mobile, & Bluetooth , Tap Reset Settings
2 weeks ago
How do I reset the settings?
2 weeks ago
