US add on
02-24-2024
06:15 PM
02-25-2024
01:30 AM
computergeek541
I purchased the $30 US add on, but I do not have the service. I turned off my phone as recommended, but it hasn’t changed a thing.
Add-Ons
03-03-2024 07:52 AM
I was able to solve my issue, thank you
03-03-2024 07:52 AM
I was able to solve my issue, thank you.
02-24-2024 08:22 PM
@parasol Here’s how to
send a private message To CS_Agents
02-24-2024 08:21 PM
Hey @parasol
Is this related to your previous post?
https://productioncommunity.publicmobile.ca/t5/Get-Support/US-add-on/td-p/1146076
About your purchase of a US add on but can't get it to work?
02-24-2024 08:19 PM
No phone number to call. All customer service with Public mobile is done on the community and private messaging/ticketing customer service agent.
Have you tried the various suggestions from your previous post?
I will likely merge your two posts soon.
02-24-2024 08:15 PM
Is there a number to speak to an agent
02-24-2024 06:24 PM
@parasol Is anything working, voice calls, texting, data? Do you have data roaming turned on? If you are trying 5G then change it to 4G/LTE.
02-24-2024 06:22 PM
You do not need to contact customer service agent yet.
First, do you see the US roaming add in your self service account? Did the payment go through?
If you see the add on, then choose either T mobile or AT&T as your US carriers. If one does not work, try the other carrier.
You can also do a network reset of your phone. Note: this will erase your Wifi saved passwords.
Here is some more information:
https://www.publicmobile.ca/en/ab/get-help/articles/us-roaming-troubleshooting
02-24-2024 06:21 PM
Hey @parasol
Go into your network settings and choose Tmobile then reboot. You should be up and running. If you don't know how, tell me if you have an Android or iPhone and I'll show you how.
02-24-2024 06:17 PM
@parasol Submit ticket with support to investigate
