01-30-2023 09:55 AM
Is the $15.00 US Roaming a per day charge or a single $15.00 fee for the entire 15 days?
01-30-2023 10:41 AM
@cmerdler wrote:So the $15 add on lets me text CAD and US numbers, and talk to US numbers only?
HI @cmerdler the $15 add on let you talk and text to BOTH Canada and US numbers
but Talk is using an older T-Mobile 2G network and it might not work great. Text would be good as it uses the LTE network. If talk is important, you might wand to use VoIP app instead. Download something like TextNow and you can use the app to call on Wifi or Mobile data (either roaming data or buy local data prepaid sim card)
01-30-2023 10:33 AM - edited 01-30-2023 10:34 AM
The $15 US add on allows you to text and call numbers in the USA and Canada, while you are in the US.
And while $15 may appear too good to be true, although the data and texting component is OK, you might find calling problematic, depending on where you are, and whether your device can manually connect to the 2G Network given the shut down of the 3G Network in the US.
01-30-2023 10:33 AM - edited 01-30-2023 10:40 AM
01-30-2023 10:30 AM
01-30-2023 10:22 AM
@cmerdler wrote:With the add on, While Roaming in the US, will I be able to text Canadian and US phone numbers?
I do still have this holiday offer on my account as well:
Holiday bonuses are for service while IN Canada only.
01-30-2023 10:21 AM
@cmerdler wrote:Can I text US and Canadian phone numbers if I add the $15 roaming add on?
Yes, but from USA only. Add not is not for Canadian services.
01-30-2023 10:13 AM
@cmerdler Yes to text when in the US but not call
01-30-2023 10:08 AM
0.0%2 GB2GB one-time data bonus2 GB left1.8%500 mins500 one-time Int'l LD bonus491 mins left
@cmerdler - those addons you have listed above (the xmas freebies) are for use while only in Canada.
Yes, with the appropriate Roaming addon you can text Canadian and USA numbers whilst in the USA.
01-30-2023 10:05 AM
01-30-2023 10:02 AM
@cmerdler US roaming is only for calls made in the US while in the US not the other way around , but if you have the international long distance add on ie more is merrier give away you can call US and all plans are international text from Canada
check add on
Check add-ons /mins /Data
01-30-2023 09:59 AM
@cmerdler Hahahahha always be wary of things that seem to good to be true I get it , but this is in fact the case you get 15 days for $15
01-30-2023 09:59 AM
01-30-2023 09:57 AM
1 x $15 charge?? seems too good to be true!
01-30-2023 09:56 AM - edited 01-30-2023 09:57 AM
@cmerdler $15 for 15 days and it starts soon as it purchased so be sure to only purchase when you ready to head off for your trip
