I’m going to travel to us
Tom1212
I’m going to travel to us. My subscription is 50GB CAN/US plan with unlimited can - us minutes. Will I be charged roaming fee when making phone calls in us?
Thanks
edited by computergeek541:  corrected the category labels as this topic isn't about "community" website discussion
10 REPLIES 10
hairbag1
@Tom1212
as already noted, there's no roaming fees while using your service in USA. Just be aware that you will need a cell that has VoLTE enabled in your settings AND is on the Public Mobile VoLTE whitelist.
hairbag1
@Tom1212
you will need a VoLTE enabled cell that's on this whitelist..
https://www.publicmobile.ca/en/get-help/articles/volte
hairbag1
@Tom1212
you will need your cellphone to have VoLTE enabled AND on the Public Mobile whitelist of VoLTE allowed phones...otherwise calls won't connect when dialed in USA.
Phil_Adelphus
@Tom1212  You will not be charged a roaming fee but you must still enable data roaming in your phone settings.
TheSterlinger
@Tom1212  with the Canada-US plan, there are no extra charge. There is overall no extra charges on anything at Public Mobile; either the service works or it doesn't but you will never be charged for roaming or overage.
Just make sure you have a VoLTE enabled phone on PM whitelist in order for calls to work.
https://www.publicmobile.ca/en/bc/get-help/articles/volte
funpig1
@Tom1212
No. It is included.
hairbag1
@Tom1212
your plan works in both countries and you won't get any roaming charges after the fact. Enjoy.
hairbag1
@Tom1212
you have a great plan that will work in both Canada and USA without any roaming charges.
hairbag1
@Tom1212
nope..you have a great plan that works in both countries without roaming fees. Make sure to enabled Roaming Data while in USA.
hairbag1
@Tom1212
nope...no roaming charges as you have a plan that works in Canada and USA. You will need a VoLTE enabled cellphone to be able to talk in USA as their 3G networks were retired...now you need a VoLTE enabled cell to call in USA.
