Data add on
Charley1313
I ran out of data on my subscription, I have already bought a data add on and also used that data up. I’m trying to add more data again and it only gives me options for Canada wide mins or US roaming data. What am I doing wrong?!
@Charley1313
if you regularly run outta data ....maybe time to upgrade to a plan with more data. Just remember that if you do upgrade, you likely won't be able to downgrade to cheaper plan later on.
hairbag1
@Charley1313
maybe time to consider upgrading to a plan with more data. Just remember that if you do upgrade, you likely won't be able to downgrade to a cheaper plan later on.
ORNGNBLK
@Charley1313   Try clearing your cache, and logging into private browser/incognito mode. Sometimes it’s a login glitch. Let us know if this helps.
