US Roaming.
01-07-2023 12:49 PM
Why does Public mobile not offer all the choices available in their self serve service.
I have been in the US over a month for circumstances beyond my control. I am a heavy data user.
I would like to see all options available . Please
Thank you
Service
01-07-2023 01:08 PM
Koodo allows you to use your minutes and data while roaming in the USA, at $12 per day (it can add up quickly). PM does not have such an option and its roaming options are much limited.
As other suggested and as you are staying for a longer period, a local US solution will be much better for you.
01-07-2023 01:06 PM
@llsham @ all you see in your account is all they have unfortunately.. but as others have already said if your a heavy data user a local sim where you are at would be a wise choice
01-07-2023 01:01 PM
But all add-on including US add-ons ARE in your account. There is no other way to get them.
01-07-2023 12:56 PM
hi @llsham yii don't see all the Roaming addon? try to use Private/Incognito/secret mode to login
but if you are there long, get local data prepaid instead, cheaper
01-07-2023 12:53 PM
Sorry you can't use any of your regular data and such in your account for roaming in the USA.
You can only buy a USA roaming add on that is available, from in your account to buy.
01-07-2023 12:53 PM - edited 01-07-2023 12:53 PM
They are there, @llsham
Go under Data and Add-On's and you'll be able to view the available add-ons there.
If you are a HEAVY data user, you're much better off using a pre-paid locally purchased SIM card there. Much better reliability and higher data plans.
Consider Mint Mobile or T-Mobile pre-paid options for 30-day plans.
