01-07-2023 01:13 PM
01-07-2023 01:18 PM - edited 01-07-2023 01:19 PM
Easiest and recommended way is to open the SIMon Chatbot and type only, "Need PUK".
Then follow the precise instructions with your device nearby.
01-07-2023 01:15 PM - edited 01-07-2023 01:16 PM
@pinkbird14 @Looks like you will need supports help
Getting help from agent
- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get
Or get help right here in the community
- Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work
01-07-2023 01:14 PM
hi @pinkbird14 open ticket with CS agent for SIM CARD PUK
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
01-07-2023 01:13 PM
You have to get that from a Customer Support Agent.
Use the Chatbot Simon to get a service ticket started.
