US Roaming - Williston ND
cgartly
I'm travelling right now and my public mobile sim will not roam on any carrier here, when I do a network scan I have the following choices:
AT&T
Sagebrush
312-770
312-330
Verizon
it does not appear that AT&T is the native network as my AT&T iPad SIM says Roaming when inserted into a device.
My friends Rogers SIM is not able to roam on any carrier, my Public SIM does not roam on any carrier here either.
Interesting to know that my Telus Postpaid iPad Data SIM is able to roam on 312-330 (Nemont Communications).
Too bad my public sim does not work.
cgartly
Yes I purchased a US Roaming Add on that was working perfectly everywhere else I was except for Williston and eastern montana.
It appears Telus applies a different roaming profile to public mobile customers than it does for Telus postpaid customers.
srlawren
@cgartly AT&T and T-Mobile are the roaming partners for Public Mobile.  As @xCameron94x asked, did you purchase a roaming add-on?
Send a msg to mod they will look after you
Send a private message with your ph#, sim# and your email mod and they will get back to you when they can.
** I am not a Mod, please do not include any private info in a private message to me.**
Nowaja
Same issue here. I bought 1GB data only add-on and cannot get any data at all. Usage in self serve still shows 0/1024. And yes, I have roaming enabled on my phone.
xCameron94x
Just thought I should ask. But did you buy a roaming add on?
