07-30-2017 12:35 AM - edited 01-04-2022 02:25 PM
i change the phone from iphone 6 plus to lg g4
after i put my simcard in , i can talk and text message but no data at all
could you help me to fix please?
07-30-2017 03:01 PM
Hi Umliun1,
I checked the link and it works currently. Also, please make sure to use this link without the dot at the end (https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/How-do-I-set-up-data-APN-on-my-smartp...)
Cheers
Abdoulaye
07-30-2017 02:42 PM
07-30-2017 12:15 PM
Hi Umliun1,
Thank you for reaching out to us. I'll be glad to assist you about your data usage concern.
In order to be able to use the data connection on our network, please make sure to get the right APN settings into your device by referring to this link: https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/How-do-I-set-up-data-APN-on-my-smartp...
Cheers
Abdoulaye
07-30-2017 12:10 PM
07-30-2017 02:44 AM
@Umliun1 the replies you've received so far are correct--if the G4 was used on any other network previously--and I'm going to assume it was since that's an older model and not likely one you just picked up brand new.
First try a network reset, and if it doesn't work, then factory reset.
07-30-2017 01:04 AM - edited 07-30-2017 01:07 AM
hopefully the network reset will work, but the G4 is known to need a full factory reset. It was based on this thread and several others with the same issue.
[edit] looks like the network reset should work as discussed in the thread @SD08 linked to
07-30-2017 12:46 AM
According to @imm1304, here's how to reset network:
https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/My-data-does-not-work/m-p/173346/highli...
Go to Settings >> General >> Backup & Reset >> Network reset
07-30-2017 12:42 AM - edited 07-30-2017 12:43 AM
If you set up the APN properly and if your G$ was on a different network before you likley need to factory reset the G4 at least once. try with sim in and tehn sim out of the phone. Cant remember which way works.
you can also try resetting the network settings
