01-23-2025
02:06 AM
01-23-2025
07:35 AM
computergeek541
Please help! Im in Los Angeles and my phone plan is Can/US/Mex but I can't make calls! I can text and use data but can't make calls. How do I fix this. Thanks in advance!
01-23-2025 05:57 AM
@rizzo123 If voice calls are a problem but data and texts work it sounds like a VoLTE issue as @BKNS27 suggested. What phone do you have? Try connecting to T-Mobile's 2G network which is still available in some areas. The USA carriers shut down 3G networks two years ago so every cell phone there now has to be VoLTE capable and approved by the carrier. If your phone isn't on PM's list you could download a voip app like Fongo or TextNow to use on wifi and data but it would give you a different phine number.
01-23-2025 04:07 AM
You will need to set your phone on VoLTE (voice over LTE) and you will need to connect to AT&T or T-Mobile network.
It also depends on the make and model of phone. It must be on the whitelist of phone that will work. Here is more information for calls in the USA:
