Call forwarding to Roaming Line
ytzslee
Hi. Three lines will be travelling to the US.  Lines #1 and #2 are Canada only.  Line #3 has Canada-US.
a) Is it possible to have the calls from Lines #1 and #2 forwarded to Line #3?  Would Line #3 receive those while in the US without issue?
b) Also, Lines #1 and #2 would still receive texts but can't send, correct?
Thanks.
1 REPLY 1
@ytzslee
please note that at the moment, Public Mobile only offers Unconditional forward.  And yes, you have have line 1 and line 2 forwarded to line 3 and line 3 will ring in US since it has Canada-US plan.
Please note that you cannot have line 1 and line 2 turned on while you are in US.  The moment line 1 and line 2 "sees" the US network, the forwarding will be cancelled.  So, best to leave line 1 and line 2 in Canda
Also, what phone do you have for line 3?  If your phone is not VoLTE whitelisted on PM network, it could be tricky to get connected to voice calls
