US Roaming Still waiting for a response
cory_c
Nov 24,2022 I posted a request for support and I'm still waiting for a response. Help with Simon is not getting any where (waste of time). 611 recorded messages is of no help.
8 REPLIES 8
cory_c
I think Simon should be gender neutral.
cory_c
Thanks! I've submitted a ticket.
cory_c
YES.
dust2dust
So you had the re-buy problem. I suggest you start another ticket or send another private message to them. You are monitoring your private message inbox, right?
HI @cory_c   you posted a request but waiting for response
if you posted here, it is just your fellow customers checking and trying to help
if you think you issue can only be helped by CS agent, you need to properly open a ticket with them
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
@Metal1967    Simon say call CSA....
                  What else.
Metal1967
@cory_c  Out of curiosity.. what did Simon say?.. 😁
Yummy
If you posted request for assistance Here, you will Not get any answer.
You have to do one of these:
To Contact CSA-agent; there are 2 methods:
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
This forum is for customers helping customers as PM staff do not visit not answer question posted here.
