US Roaming Data
proro
In the near future, will PM consider lengthening the time of US roaming data for more than 10 days? This would really be appreciated by snowbirds like me who live in Florida for 2-3 months. Thanks for responding.
dust2dust
Only the company knows. I doubt it. It likely wouldn't be worth it though compared to getting local service. I'm looking at Red Pocket through ebay. Averages out to $2.50USD per 30 days. Low usage (but probably more than what I use now 🙂 ) Some seem to like Mint. Another has discovered a data-only service from Keepgo which is very intriguing when you use a voip app.
It's just that all of these options don't use your phone number. There are workarounds though like forwarding to that voip app and leaving the sim at home. Then you get calls on the voip app.
HI @proro   I think you need to private message them directly to let them know the needs and demands are there
But for 2 to 3 months, it is MUCH BETTER and CHEAPER to use local data sim with FREE VoIP app.  Just a suggestion.
Yummy
We know as much as you do as we are all customers here...
I doubt PM will offer longer US roaming and/or lower prices.
