US Data
Nick44
Hi
just switch to can-us data plan.
got the 5G in the US but unable to use internet
Any thought
7 REPLIES 7
@Nick44 wrote:
It work on T-Mobile
but will have to do that every time
Not really. When you go to your network cellular settings, just turn off automatic and pick T mobile. It should stay there.
HI @Nick44
Try both AT&T and T-Mobile but do not try 5G.  Easier to get 4G.  Go to Network type and choose 4G or LTE
Nick44
It work on T-Mobile
Pick Tmobile
Nick44
Yes data roaming
Is picking AT&T
Priority
Do you have Data Roaming enabled in Cellular Settings?
Which Network is your phone picking up on in the US, T-Mobile or AT&T?
@Nick44
Dunkman
@Nick44
Try to manually select T mobile carrier.  If that does not work, try AT&T.  Choose LTE network instead to see if that works better.
Here is some more information about trouble shooting:
https://www.publicmobile.ca/en/ab/get-help/articles/us-roaming-troubleshooting
