08-26-2023
01:04 PM
08-26-2023
05:14 PM
Dunkman
My son just called me saying his Data in the USA is not working. He has the CA-US 20GB plan and has an iPhone. I need assistance how he can get his data. I am leaving to the USA to meet him on the exact same plan in a few days and do not want the headaches. Was with Virgin before and the US data plan never worked, 1 major reason we switched companies.
Please help
08-26-2023 02:08 PM
I agree with the above. I would leave it on automatic. If you get out of coverage for T-Mobile then it could connect to AT&T and vice versa. I would also leave it on 4G LTE but that's just being cautious. And hopefully your phone has been enabled for volte by now. Otherwise you'll need to be able to switch down to 2G GSM for T-Mobile for talk. Text will also work on that. AT&T will not. This is just about talk. Text and data should be fine on both on 4G LTE.
08-26-2023 01:52 PM
Most of the time you should be able to leave your phone in Automatic network selection. Only if it doesn't connect to T-Mobile would you need to manually connect. The bigger issue I find people forget is to enable data roaming within the network settings on your phone. Just leave it on all the time, as there's no chance of overages on PM anyway, because it's prepaid. Either the service works, or it doesn't.
08-26-2023 01:29 PM
Ok great. Thanks
08-26-2023 01:22 PM
Wonderful! Very happy to hear that this got it working for him.
Yes, unless you get automatically connected to T-Mobile you will most likely encounter this issue so I’d suggest manually connecting to T-Mobile whenever you go across the border. Also with automatic turned off now, remember to manually select Public Mobile when you return to Canada.
08-26-2023 01:20 PM
It worked thanks so much. I guess i will have to do the same once I am in the US
will this have to be done each time we enter the US
08-26-2023 01:13 PM
Yes, turn off the phone and then turn it back on.
08-26-2023 01:13 PM
Will doo
08-26-2023 01:13 PM
When u say reboot. You mean turn off the phone?
08-26-2023 01:12 PM
Hope this helps! Please keep us posted if this solves the issue for him.
08-26-2023 01:10 PM - edited 08-26-2023 01:11 PM
@TanyaWaiz reboot the phone . And make sure your connected to T mobile and another thing you can try is resetting the network settings and that data roaming is on .see if that helps any
08-26-2023 01:09 PM
Sending him the info right away. Thanks
08-26-2023 01:08 PM - edited 08-26-2023 01:08 PM
Make sure that data roaming is on. Go into your cellular settings, hit the SIM card you are using, then go to network selection. In Network Selection turn off automatic and manually select T-Mobile, then reboot
