US Data Roaming Doesn't Work
Zhenya1245
I can't get my data roaming services to work in Chicago. Tried everything. Chatbot sucks and won't let me submit a ticket. Help!!!!
Dunkman
Phil_Adelphus
@Zhenya1245   Have you checked that you have data roaming turned on in settings, and are connecting to AT&T or T-Mobile on 4G/LTE (don't use 5G).   Do voice and texts work?
@Zhenya1245  Make sure you have data roaming turned on in phone settings . And out phone to 4G/LTE and connect to T mobile or AT&T . If still issue with voice try phone to 2G and only connect to T mobile . But this direct link to support will work should you need to get ahold of them
send  a  private message   To CS_Agents
TheSterlinger
Make sure your connected to either T-Mobile or AT&T then try scaling down to 4G or 2G if that’s works.
If not then you can submit a ticket to a Public Mobile CS agent.
