05-29-2020 12:21 PM - edited 01-05-2022 10:57 AM
Hi All.
It won't be anytime soon but at some point in the future I plan to travel through the US for a bit to go out west. After reading about the various 10 day US Add-Ons I'm sure one of them will suit me fine but I have a question as I didn't see anything about it when going through the community posts.
Will the US Add-On be activated and the ten days start as soon as I make the successful purchase or is there an option to start at a later time (eg a day or two later)?
Thank you.
05-29-2020 03:05 PM
@dabr wrote:
@Danchvn wrote:
@mimmo wrote:you can purchase them by phone while in the USA by calling 18554public you will need to know your pin number though.
@mimmo Great to know. I will have to write that number down.
@Danchvn Perhaps it might be easier to just save it in your contact list 😊
@dabr Ya...guess I could do that. 🤔 Would be better than trying to find that scrap of paper when I need it.
05-29-2020 02:21 PM
05-29-2020 02:18 PM
05-29-2020 02:14 PM
05-29-2020 01:33 PM
@Danchvn wrote:Hi All.
Thank you.
You can buy the 10 Day US Roaming add-on while using free wifi in US...such example as Wallmart and most cafes have free wifi today.
05-29-2020 01:08 PM
05-29-2020 01:07 PM
@Danchvn if you use 611 from your phone to buy an addon you require your 4 digit pin code to do so.
05-29-2020 12:50 PM
@mimmo that is very helpful information. Did that come directly from the website or because you are an oracle it is like inside information? 🤷♀️ 😸
05-29-2020 12:47 PM - edited 05-29-2020 12:48 PM
Make sure that is a valid credit or debit card on file in order to purchase add-on from your phone. OR
You can also add fund to your account using topup voucher before leaving Canada.
Please note that if you purchase your US add-on at 11pm ET, it will count as 1 day for 1 hour usage.
05-29-2020 12:32 PM
05-29-2020 12:25 PM
@Danchvn That is correct, the add-on becomes active as soon as your purchase it and the 10 day counter starts.
or is there an option to start at a later time (eg a day or two later)? Unfortunately that option is not available.
Thank you.
05-29-2020 12:22 PM
Once you purchase the US roaming add-on it will expire 10 days after purchase.
